This may be a simple stupid question but i'm a bit stumped.
I just installed two WD 320 gig drives in a rig and installed XP slipstreamed with SP3 on one of the drives which is the C drive. What is weird is both were partitioned the same, etc...but under disk management Disk 0 which is the C drive is showing a capacity of 298.08GB. The D drive Disk 1, exact same model drive(same firmware also) is showing a capacity of 298.09GB.
Using a program called Disk Checkup by Passmark it shows the C drive capacity as 305234 MB. For the D drive it shows 305242 MB.
Not a big deal just curious as to what would cause two identical drives to have differing numbers like this.
Thanks.
Thanks.
