Question about g33m-ds2r + 8600gt
siralexu
A while back ago i upgraded from a 8600gt to an 8800gts 512 and the old one has been sitting in its box but i was wondering since my motherboard has an aditional pci-e 4x can i plug the 8600gt just to do physx will it work? and will my motherboard accept both graphics cards at the same time?
Additional note for other people: The 4x slot is open ended. It'll physically fit.
And it should work in any case (as far as display goes). No idea about PhysX.
from what ive read the 8600gt is supported as a physx card just wondering if it can draw enough power from just that small slot seeing that its not a full lenght one
I have the G33M-S2 (same board w/o RAID) and I use the 4x slot with a second video card for additional monitor outputs. I know it's also capable of crossfire, so you shouldn't have any problem using it for physx.
Yes it'll work. I've also done dual-vids in my DS2R. And as Seggybop already pointed out, the board is officially sanctioned for Crossfire setups, meaning the bottom slot can power a video card.
