KnishofDeath
- Aug 27, 2004
Ok here goes, If I hook up my iMac to the Fubar IV via USB, then hook up my PC via the optical connection will both output to to my speakers? (Swan d1080MKII) I will not be playing audio with both at the same time, just don't want to unhook stuff.
Also just to make sure, when I plug in headphones to the amp it should cut the speakers off yes?
Just want to make sure this will work the way I expect it to before I spend the money, thanx.
