- Dec 2, 2009
ok i just bought a thermaltake ISCG fan
http://www.google.com/products/catalog?q=thermal+take+fan&hl=en&cid=2235937985792451354&sa=title#p
for my h50 radiator. (just trying out diff fans) i installed it the correct way i wanted it according to the arrows (as an exhaust) but when i turn it on, it feels like the air is being blow into the case because i can feel more air going into the case than leaving. is it possible the arrows are facing the incorect way, or does the fan not generate enough pressure?
