dariob said:Probably not. Unless they are recognized by BIOS, which I would say is next to nihl.
Othersider said:Uh, most modern BIOS have a "boot from USB" option.
dariob said:You may be able to boot from it, but the windows install prog is looking for an internal floppy, not a USB device.
zoobaby said:If you can boot from it, you can install off of it. That is what boot from implies.
dariob said:Have you tried it? The XP install comes on a CD. Just because you can boot from a USB device doesn't mean that the XP install prog will recognize an attached USB floppy as a floppy drive.
