bpimmerman
- Dec 5, 2001
I haven't posted in a long time, and i've been using a macbook, so i'm pretty out of the loop on most things. I need to upgrade the HD, get two external enclosures (one 2.5" for the old HD as a spare, and one 3.5" to put a backup into), and one 3.5" drive to serve as a backup and movie store.
I was looking at newegg at the vantec nst-360SU, which looks to be a solid case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392002
but I would want to get a 750gb now, and have a potential to upgrade as sizes increase over the next few years. However, the case says that it supports drives up to 500gb. Is this true? how can a case determine what size HD you put in?
As for 3.5" HD, i was just going to get the cheapest 750gb with a five year warrenty (brand name of course).
I have another 3.5" samsung 200gb lying around that i might get a third enclosure for as well.
Any other recommendations for cases (or HDs that you love) would be welcome, I did a search but couldn't find much.
Thanks!
Thanks!
