TheMadHatterXxX
- Sep 7, 2004
I got my new parts yesterday along with the PSU, I connected my watercooling unit to it only and was testing for leaks before i put in my system and parts, inorder for the Koolance Exos unit to work this way it has to be connected to the powerswitch on the tower and the 4th and 6th hole on the ATX 20something pin cable have to be shorted with a lil wire, it was working for a while, the PSU was working i think-because the fans were running...then i turned if off-i forgot how, maybe I should have used the I/O switch on the back of the unit instead of removing the jumper wire from the power supply atx cable...but anyway after i did that i refilled my watercooling unit with more solution after i ran it to get the airbubbles out, and then i tried to turn it on and the powersupply didnt work.
So i got really dissappointed and wet to bed 4 am after trying everything ....woke up at 8:30 today, tried it again and it worked! What's going on!! Is this normal? Did I accidently cause a short last night and it just needed time to heal? I hope its not damaged....I spend $160.00 on it and hope it wont cause my new parts any problems....did this ever happen to anyone or anything liek this where it'll work, stop working for a while and then become fixed again?
