bookworm316
- May 23, 2007
Hi All
Quick question. I was wondering about HDCP and how it works. I know you have to have a video card that supports it and also a monitor that supports this as well. I already have a DX10 video card that supports HDCP and will be getting two 22in monitors that will have this as well. Does the DVI cable need to be HDCP compliant or can you use any DVI cable?
Thanks for your help in advance. I know its a dumb question but I just want to make sure.
Thanks.
Thanks.
