Can you have a DVI and D-sub input plugged into the back of the 2001fp, and then switch between the two?
I would like to know if I can have my AIW 9800 Pro hooked up using DVI, and then my Xbox hooked up using D-sub through the Neoya X2VGA High-Def VGA pack.
Thanks. I'm thinking about ordering this today for $750 (before it goes back up to $1000).
