Question about Coolermaster Aquagate
skandaluz
Does anyone know what size the tubing is that comes with the Coolermaster Aquagate watercooling kit? I was planning on getting that watercooling kit and getting a different cpu water block like the swiftech apogee or storm but didn't know if those two would work together. Also, Would this kit be able to handle another waterblock as I want to add a GPU water block to the loop. TIA
I think it's 3/8". Honestly, you'd be better off with a real kit. It would be more expensive, but you'd get better performance and the kit would be able to handle more load. The Aquagate probably wouldn't handle the heat from a modern CPU and GPU very well.
