Question about connection PC to x360.
no0ne
Hello. What processes or "things" (?) can block connection between my PC and xbox 360 ? I have connected my xbox 360 and PC with a ethernet cable, and that connection and all that thing worked for me about 4 months, but one day something happened. Suddenly i have been disconnected from XBOX LIVE and from then i can't do any tests ( XBOX LIVE and Media test). But point is not here. The point is, in those tests i can't complete IP Adress test :( As i said, everything worked fine and i do not changed any settings anywhere. In "more info" it says, "Your gateway did not respond to network request". After that i have tryed to turn off all possible firewalls, to create new network connection( not suceeded) and re-configurate all settings, but still, same thing. And other thing. I go START -> RUN -> and typing "ping -t 192.168.0.166" and all the time it says " destination host unreachable". As you figured out already i think, i have made a Connection sharing to my xbox from PC, and all settings in my xbox are correct. So, what the hell happened ? Does something is blocking that connection ? But everytime when i turn on My xbox, in PC it says " Connected local area connection 100mbps". Everything seems to be OK, but there isn't..
If i'm in wrong section sorry, and Sorry for my bad english .
Seems the XBOX is not getting an IP address in the same range as your PCs NIC? Was it manually set before? Or obtain auto?
The IP in xbox was set manualy by owner, who has my xbox before. And it worked fine.
