Question about Coil or Cap noise + games
4LC4PON3
DERP!
Ok i got a ? my 5850 has either Coil or Cap noise. while in the Menu of stalker its Clearly noticable the Sounds Very from Low to High like a grinding noise depending on what menu options you click on.
Now ive read on the internet ALOT of people have this problem and it seems it only does this in crysis and stalker Main Menu because if you look the FPS is over 1K causing Coil whine. Now Would this be a graphics card issue or a Game issue? is there anyway to lower the FPS in the Crysis and stalker Menu's (Like set a Cap)
Ive also read there are Fixes you can try. I got Refused for my RMA because they said its not a problem and id like to try and Dimm the Noise down some. is there a Guide on how to do this?
Ive read that you can use Clear nail Polish on the Coils but to be honest i dont even know what the Coil is.
Does it do it in the actual game, or only the menu? If it is only the menu, your best bet is to just live with it. It often gets better over time.
