Question about CNPS9500 LED
luke51087
If anyone has this installed do you need to remove the stock plastic housing on your motherboard and backplate? i ask this because i have a NEO4 SLI PLAt SLI board, and the backplate is glued on and i also am to lazy to want to remove all my stuff from the board.
no you don't have to on s939. i don't know about the others but i used to have it and i din't remove any plastic on the mobo.
yes they plug on 12volts. and don't get from newegg they are a bit more expensive, try zipzoomfly.com and they have free shipping.
Ok so i can plug both of the VGA coolers into only one splicer? i see they have 2 ports for 5v and 2 for 12v that come with each card? is this meant for my SLI Solution?
correction to this i think my boards layout is to close to fit one on both cards i am going to probably buy one and the cpu fan and set it up. My one 7800gt has a Copper heatsink so ill probably switch out the Alum one with the zalman
Does anyone know if i can get 2 of the 900 models in there seems like they are shorter
