Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Had this case for a while and always wondered what this was? It is probably a really stupid question, and I'm assuming it is a really bad wire management system? Thanks!
Heh. Is THAT what that is! Having had several of these style cases, I figured it was an easy way to manage some cables (stuffing the extra in it without cable ties ).
thread hijack: muwhahaha. (he got his answer anyway)
while we are on these cases, are there any optional mounts for 120mm fans in place of the 80's these cases use? Or, have any of you creatively mounted 120's in these cases? I'm going to mount one in the top, but would really love to put one in the front as well (I havent really looked at the front well yet). I've already removed the bottom hd cage and am going to drill out the rivets that hold the cage bracket in place, because the damn thing annoys me.
well thats obvious..looking for something a bit more comprehensive. I honestly dont know that I'd bother cutting a hole. there are 2 80mm fans there already, a fan properly mounted inside should draw more than enough through the existing holes.
But you have to remember that you will be effectively restricting the airflow by only drawing through the existing holes for the previous 80mm. Your best bet is to get a template for a 120mm and trace on the case and cut it out. Take a look at the HD 100th Anniversary case at www.mnpctech.com to get an idea of what you are looking at.
