M
MantisIT
Guest
my AM2 3800+ X2 running almost 12'c cooler than the e6600 C2D.mzs_biteme said:Both CPU's will run cool enough.
Conroe will run cooler...![]()
jhartono0002 said:my AM2 3800+ X2 running almost 12'c cooler than the e6600 C2D.
AM2 idle temp at stock 35'c
C2D 47'c
mzs_biteme said:Or wait for the Nvidia R600 chipset mobos for SLI.
Good luck.
brucedeluxe169 said:unless you are going for very low budget, it makes no sense to buy an AMD system
that made me laugh alot
The temperature readings aren't measuring the same thing. The E6600 also consumes significantly less power than the standard voltage X2 3800+.jhartono0002 said:my AM2 3800+ X2 running almost 12'c cooler than the e6600 C2D.
C2D 47'c
Get a zalman 9500 and be set for life with itRailGunRiz said:Well I am not much of an overclocker, but its something I would like to do in the future. Would I need a new CPU HS or does the stock one suffice?
And your gigabyte mobo, which one would you recommend?and what kinda ram would be better matched with it?
i think high temp on my C2D is caused by non flat IHS (convex).SLee said:The temperature readings aren't measuring the same thing. The E6600 also consumes significantly less power than the standard voltage X2 3800+.
http://www.xbitlabs.com/images/cpu/core2duo-shootout/power-2.png
using scythe ninja, same heatsink, yesmzs_biteme said:Same heatsink on both...?
C2D 47'c
MC FLMJIG said:Problem is many boards default at 1.8 and some memory needs higher to boot... People just don't know that.
RailGunRiz said:Well, because every, and I mean EVERY, Asus board that I've owned (p4C800-Deluxe, A8 deluxe, a8 premium, a8r32mvp ect) have all died within the first week of opening / installing them. I've had a DFI boards/ Epox boards that I could throw down the stairs and still have them boot up/ not give me any problems.
Asus is flat out a shitty motherboard company, and their boards are no different. Their customer service dept is the only place where the operator tells you "we'll call you back" and never get back to you. + RMA's take FOREVER with them, I waited about a month to get my old P4C800 Deluxe back a year ago, worst thing ever. Besides they're too damn expensive even for their "budget boards".
RailGunRiz said:lol I didn't mean to come off as yelling at you bout it. Its just that company has literally fucked me on every board they've sent me. I'm the idiot who keeps buying them but, no more.
I just ordered the C2D E6600 / Gigabyte DS3 board (4G of patriot DDR2800 as well) we'll see how things turn out.
Thanks for all your opinions.![]()
Donnie27 said:What you say about Asus is exactly what happened to me with Gigabyte. Yet, I own a DS3. Then add to this I've never bought an Asus board that was bad. The one that sucked the most had a VIA chip set that sucked on every board makers board. I think the first Asus board I owned was P2B, then quickly added P2B-F, 3 P3B-F's, A7M (the one that sucked but worked). P4T-E still my favorite i850, Asus A8N (still using) and so many built for others I can't possibly remember them all. In fact, I just worked on a lady's computer I sold to her 8 seven years ago Asus P2B-F with a P3 450MHz.
NulloModo said:I am still on an Asus P4P+ (i845 chipset), works fine for me, but since S478 is dead, not much of an upgrade path. I am going Apple anyway, the 24" iMac has too good of specs and is too sexy to resist, I can just get some firewire enclosures for my current hard drives to get to my files anyway.
Via made the chipset of the only board that died on me (and took my first K6-2 450 with it). I don't remember who made the board, it was before I became knowledgeable in the tech field.
mzs_biteme said:Both CPU's will do great in gaming.
Conroe will do a little better (at stock, in benchmarks)![]()
Both CPU's will overclock well.
Conroe will overclock much better![]()
At stock, in games, you will not see/feel the difference between the two.
Overclocked (3.3~3.6GHz average), Conrore will have much greater impact on your games, and you'll actually notice it. But then you'll be limited by your GPU (no SLI, Crossfire..)
Get a Gigabyte mobo. Or wait for the nForce 680i chipset mobos for SLI.
Good luck.
OP said:(AM2 or C2D motherboard (NOT ASUS) *
(AM2 x2-4800 or C2d E6600)*
Patriot DDR2 800 Ram or Corsair DDR2 XMS2 800*
XFX 7900GTX 512
Auzentech X-Plosion
WD 250G HD SATA
UnlimitedMP said:How about in the long run when games are not so gpu limited? Which would be the better choice (compare mid-range chip amd to mid-range c2d, higher end to higher end)?
Case1: stock
Case2: oc'd to average oc's ppl have been getting.. rough estimate since OCing varies
Good luck.
Asus is flat out a shitty motherboard company, and their boards are no different. Their customer service dept is the only place where the operator tells you "we'll call you back" and never get back to you. + RMA's take FOREVER with them, I waited about a month to get my old P4C800 Deluxe back a year ago, worst thing ever. Besides they're too damn expensive even for their "budget boards".Call Samsung, Sony, DFI, Epox, Kingston, Viewsonic, just a handful of company names, and have them call you back.
Whoever believes a company will call you back, has it coming to them. Do you realize Asus is a multi-billion dollar company, and for some kid who kills a motherboard a week, they are not out for your audience. They want people who love computers,and know what there doing. If I owned a shop by you, I would refuse service to you probably after the 2nd board, maybe third. Simple as that, I say you don't know what your talking about. Lets see you throw a DFI or Epox board down the stairs and see it still boot? Our schools philosophy / debate team would tear you a new one kid.
My experiences line-up different....
I remember...Epox...the laughing stock of motherboards. The most unreliable even @ default. I had to replace a few of these POS boards with some real top tier boards every time.
DFI.......well they haven't had a bad name, the shop I worked at never carried them, except for K6 boards. Asus is #1, but DFI has came a long ways I hear.
Asus just posted all of its quarterly profits and what not, they are still #1. I think Kyle would agree, Asus is a top quality tier producer of hardware. You don't find brands that make top of the line video card, motherboards, and other snazzy stuff.
I used to work at a shop and we sold probably off the top of my head around 1,000 Asus boards yearly, if you figure roughly 3 a day. Which was no problem, and we saw Asus come back the least, even though we sold them the most. Which is contrary to what stats for that should be.
I will be the first to call BULLSHIT. On someone owning like half a dozen new in box Asus boards DOA's or dead within the first week. You killed the boards overclocking them, or mishandling them, or just like the movie "My Name is Earl", you have serious issues with karma. But I repeat, Asus is literally the #1 brand name, and #1 in quality motherboard. I would like you to show me a company with a better track record.
Asus does not market their motherboards to the "Best Buy / Circuit City / Wal-Mart" crowd, which is one clear difference between them and Epox.
