question about buzzing samsung LCDs
orgasmatron
Bad news for Potential 173T buyers
*Update 11/7/03 - The Final Word: I spoke with Samsung public relations and here is the final word as far as what Samsung is claiming happened. For 2003, Samsung is using a PVA panel with a 700:1 contrast ratio in their 173T LCD monitor but in 2004 will be switching to a panel with a 450:1 contrast ratio due to limited supply of the original panel. So instead of advertising the 173T with a 700:1 and then switching it to a 450:1 contrast ratio spec in 2004, Samsung thought they would do us all a “favor” and advertise the 173T as having a 450:1 CR from the start on SamsungUSA.com. Then when they switched the panels out at a later date there would not be a need to update the spec. The problem which I discovered, was that Samsung Canada and some retailers decided to go the other route and to advertise the 173T with the correct contrast ratio spec now, and to switch it later. There is no doubt that this monitor is a beautiful monitor to look at, but if you want the current 700:1 contrast ratio, you need to rush out to the store and buy it before 2004 when they will be switching to a different PVA panel featuring a lower 450:1 contrast ratio. We will be re-reviewing the monitor at that time.
