hi all,
i want to build a very basic HTPC case for a 780g motherboard. specifically, the GA-MA78GM-S2H.
the motherboard is 9.6x9.6 inches according to newegg, so i plan to build the case around that.
i plan on using:
GA-MA78GM-S2H (as mentioned)
some low power amd processor
5400rpm notebook harddrive
seasonic psu 330w
my goal here is minimal heat/minimal noise.
Here is what i got so far (cad layout):
http://i455.photobucket.com/albums/qq275/jcmuse/CASE.jpg
i'm planning on building this case out of stainless steel. i have a friend that owns a stainless steel fabrication warehouse so i plan on taking advantage of that to have the case built there. I figure the thicker steel i use the quieter it will be. I don't really care how much it weighs. is there any reason against using stainless steel? i dont know anything about gauges/grades etc but the stuff he builds is for restaurant counters/tables and shit so i imagine its pretty high grade
the powersupply will sit on its side in case you can't make that out.
i've never built a case before so i still need to learn how to wire up the LEDs, and power switch (f that reset switch, don't use it).
i'm not set on any of these components or the design for that matter, so im open to suggestions..
i plan on using:
seasonic psu 330w
