computerpro3
LightningRod
- Mar 29, 2003
Hi,
I have a couple of quick questions regarding bridging two fios connections.
In my new place (which will be wired up with an overkill of Cat6 to each room, among other things) a 50/10 fios connection is $99 a month, while a 30/10 is $59. There is no option for higher upload speeds unless you go with 100/20 which is a ridiculous $300 a month. I saw someone in the "post your bandwidth thread" who had two 30/10 fiber connections and he was bridging them to achieve speeds of 60/20.
Upload speed is extremely important to me as I'm trying to backup two terrabytes of data to crashplan, so if it's possible to get two of the 30/10's and bridge them that's what I'd like to do.
I've done some preliminary research and know that I need a dual WAN router. What I'm not sure of is exactly how it works.
Are the two connections simply load balanced, so on a single connection like a FTP for example I won't really get 60/20? Or are the connections actually combined so that I would be able to utilize a true 60/20 pipe regardless of what I'm downloading or uploading? If the former is the case, how common is this - do most things utilize multiple connections so I would be able to get 60/20 (like crashplan, for example)?
Also, how difficult would this be to set up? I understand that I won't be able to do this with a consumer router, but I have very little linux experience and I've never played around with managed firewalls/switches/etc. I'd be willing to learn something like pfsense (always good to expand your knowledge), but I'm just wondering what I'm in for.
