question about bios flashing
So I just picked up a 1090t,mobo,cpu and ram combo off fleabay,I already have everything but the cpu sold,as I am keeping that for my self and that brings us to my question.
The motherboard I am using now (790fx-gd70) supports the x6 processors with a bios update,but I have never had to flash a motherboards bios,I honestly have no idea how to do it,so I am just looking for any pointers,things I should do before I attempt the flash and how can I keep the board as safe as possible during the flash,reading instructions on the process makes this out to be a dangerous and daunting task to say the least,last thing I need is a bricked mobo that is out of warranty.
While I was looking for the updated bios file on the msi page,I noticed a link to the msi live update as well as the steps to upgrade the bios file using this method.Has any one had any experience with this program,it would make things much simpler to just use the live update if the program is reliable and safe enough.
if you can boot into windows with the x6 you can update it through windows. otherwise if you can't get to windows but can get to the bios you need to stick the bios file on a flash drive, if i remember correctly msi does have a feature in their bios to update it through that. you might have to check though.
