DarkSamurai2003
- Jul 16, 2003
How much of an improvement is ATM vs Frame Relay, and what is ATM Exactly and what is Frame Relay?
Isn't that what Verisons FIOS is? I don't know if they use ATM specificly, but I beleive the do use fibre optics for it. Maybe he is some manager though, one of those that doesn't know the techincal stuff, but has to work with the IT people that do?LonerVamp said:I'm surprised you're getting ATM directly to your residence? You might have hit some marketing fluff in that the ISP is at an ATM point and from there it gets all split down to you and other customers. Otherwise, you would have fibre right up to your doorstep.
Also, you are currently on what's called "Framed Relay" DSL, this is older technology that is being phased out. When you upgrade to the 3.0/768 program that is the new ATM DSL. You should be quite happy with that.
