I'm looking at building a SFF computer for some basic file storage/media server. I'm wanting to use the Apevia X-QPack case. It comes with a 420W power supply. Below is a link to the specs for the case. I need to know if the power supply will be good enought for the components I will be using, they are listed below. Also, I may look at adding a PCI-e video card later on.
http://www.apevia.com/product.php?pid=185
Components
Components
- Intel Pentium D 920
- Intel DG965OTMKR
- Corsair XMS2 1GB (2x512MB) TWIN2X1024A-6400
- Seagate 80GB SATA
- WD SE16 400GB SATA
- NEC 16X DVD-RW
