Question about AMD's SuperSampling
I want to apply Super-Sampling to some games that support it. However, there are multiple filers listed under the SMOOTHVISION HD: Anti-Aliasing menu when I want to adjust the level of Super-Sampling. Do these filters affect the quality of the Super-Sampling and which one is the best to set out of Box, Narrow-tent, Wide-tent, and Edge-detect?
Supersampling AA will work with the in-game AA or if you force AA through the CCC panel, I would recommend you use the box filter which is just standard MSAA, and then set the slider quality to supersampling, this will apply the supersampling AA method to whatever sampling rate you're using, such as 2X or 4X. You can get away with 4X SSAA on all but the most demanding DX9 games. For those games you may have to reduce it to 2X SSAA. Even 2X SSAA looks as good if not better in many cases than traditional 4X MSAA.
