RancidWAnnaRIot
EspantaPajaros
- Feb 19, 2004
OK this is the first time i will build a box with a SATA harddrive.. my questions is .. does the motherboard bring the drivers nesseary for SATA?
Is this the correct way to install a SATA drive and then install windows on it
1) pop in XP Cd.. press F6
2) pop in SATA driver floppy (i believe it comes with the board)
3)press S and install drivers.
after that the install utility on Xp should see the drive and procede with partitioning and format...
Is this the correct way to do it?
Or am i missing something?
