Question about A8N-SLI DELUXE
qtqc
Hello everyone, Im looking into doing an upgrade soon. I been looking at the Asus A8N-SLI Deluxe with an AMD 3800+. My questino is do the new SLI mobos still have AGP video support or would I have to pick up a SLI card. Im eventually going to upgrade to SLI but for right now Im happy with my 6800 agp. Thanks for the help.
BTW heres a link on the mobo Link
These boards do not support AGP cards. Look a little closer at the specs. Video card support is PCI Express.
Im assuiming the premium with have support for both AGP and PCI Express?
No, the premium does NOT support AGP. No Nforce4 board out (that I know of) supports AGP. And SLI is not the new type of video connector, it's PCI Express.
The reason ohnnyj said you might want to hold off for the premium version is it will most likely not have some of the problems of the deluxe (which I own). On top of that, it doesn't have a physical mechanism for switching between single and dual graphics card modes, which is a plus.
I myself have had zero problems with my A8N-SLi. However holding out for the Premium is not a bad idea at all.
PCI-Express is the new video card connection standard. SLi is Nvidia's proprietary interface for linking two video cards together to enhance performance.
It should be soon, hopefully, as ASUS has announed it and even said that it has begun shipping it.
And I didn't even notice this before but the whole intelligent multi/single switch actually allows you to disable/enable SLI in Windows so that you can be running mulitple monitors (up to four) off of the two cards running independently (as only one is allowed during when SLI is enabled). At first I thought it was only a nice one time thing for installation relieving the necessity for having to manually change the selector card. Obviously it does this but much more. If this is true then no more rebooting to have multiple monitors. One can select the dual card mode for up to four monitors then quickly switch to SLI mode for a gaming session, now this would be nice.
Linkage.
Sweet. I just hope the new board OC's well. I'll get one if it does. Otherwise I'll probably pass as the lack of a selector card isn't enough to make me buy another board again.
