deathrament
- Jul 14, 2019
I bought a usb headset(Arctis pro no dac) and a sound card. I didn't realize that the sound card would be useless with a usb headset. The headset does however come with a 3.5 mm adapter. so i'm wondering then if i use the adapter and plug it into my sound card, will the headset then use the sound card? If so will i loose any of the sound quality. I want to know before i open the sound card.
