Question about a low budget gaming video solution
Fixer
My first inclination when offering advice to a friend about computer parts is to go with premium parts like a 7950. I am however trying to recommend a $1300ish system for him, so I am exploring some more of the medium range cards. I however have no experience with either the 7600gs/gt nor the 7900gt.
I found a decent SLI motherboard, so SLI is an option. All cards below are PCI express 16x. All solutions are between $300 and $315.
The 3 options i was looking at are:
2x 7600GS 512MB 128-bit GDDR2 in SLI
http://www.newegg.com/Product/Product.asp?Item=N82E16814130021
2x 7600GT KO 256MB 128-bit GDDR3 in SLI
http://www.newegg.com/Product/Product.asp?Item=N82E16814130017
1x 7900GT KO 512MB 256-bit GDDR3 Reload
http://www.newegg.com/Product/Product.asp?Item=N82E16814130034
Any suggestions would be appreciated.
i believe the 2x 7600gt's have close performance with the single 7900gt? in this case i'd say get a single card, dont have to worry about sli stuff and heat and what not. And it gives him options to upgrade.
