Question about a fan controller
P
ProjectChaos
Guest
Hey guys,
I'm running my 80mm tornado on my nexus fan controller, 1 question though. When running your cpu fan through a fan controller do you have to plug the cpu fan into the connecter that says CPU Fan on the motherboard? (epox 8rda+ btw). Because as of now I don't have it that way and I dont see how you could do it like that seeing as there is only 1 connecter on the part that goes to the fan controller.
Thanks,
~pC
no, you don't need to, but if you want to monitor your fans rpm you will want to plug that into the mobo.....at least I think it works that way.....
