I've been away from the Video Card world for a while, and it was about time for me to upgrade my system.
I've been running:
AMD Mobile Athlon 2600 @ 2.4ghz
Abit Nf7-s Rev 2.0
512 MB Ram
ATI Radeon 9000 (after my Radeon AIW 9700 pro died)
IDE 160GB WD hard drive
SATA Seagate 160GB hard drive
But I plan to run:
AMD Athlon 64 3500 Socket AM2 (http://www.newegg.com/Product/Product.asp?item=N82E16819103633)
Still looking for a good AM2 motherboard which overclocks relatively well.
1GB of Ram, not sure whether to get DDR2-667 or to spend the extra buck and get DDR2-800
But anyways, after looking around a bit, I decided upon a 7900GT.
I was looking specifically at the EVGA 256mb 7900GT (http://www.newegg.com/Product/Product.asp?item=N82E16814130033)
However, I've heard some problems people have been having with overclocking the card. Apparently, if you OC the card, there tend to be some number of deaths, or a few cards with random artifacting after the card has been stable with an OC for a while.
I was wondering if you had any suggestions or warnings about this?
I'm willing to spend up to about $300 or so on a card, so if you have any other viable suggestions, those would also be welcome. Plus any suggestions on a motherboard or what ram to get would be great.
I've been running:
Abit Nf7-s Rev 2.0
512 MB Ram
But I plan to run:
