question about 7800gs.
Napalm=)
will a 7800gs be able to run cod2, hl2, cs:s, bf2 and others at 1680x1050 at decent settings?? what about a 6800gs??
I used to own a vanilla 6800 128mb card, I could run CS:S/HL2 at 1680x1050 with decent AA+AF, but I had a few things set lower, ran really well. COD2 should work at that resolution with a 7800gs but I can't gurantee it. BF2, unsure...
The rest of your system specs will be quite important to some of those games, like the amount of ram and processor you have, primarily.
HL2/CS:S definately, the others... you may need to run it without any AA and possibly reduced settings.
I will give you a tip.
Look for a 7800gs with the g71 chip. This one can be overclocked much better then the g70. Overclocking the 7800gs is very important to get the best performance out of it.
With a good CPU you are going to be GPU limited, so every extra mhz helps.
I run an opteron 170 system with a g70 7800gs. I have done a volt mod, and I can reach 500/1500... and that is really good for the g70, however the g71 version can go farther then this without any modding. With modding it can reach insane speeds... 600+ on the core.
Anyway, since you have an LCD, I would get the x1950pro AGP... you need all the power you can get since you have a set native resolution.
well i wanna get a 22". i thought the only g71 core was the gainward bliss??
i used to own that card. Shit, I used to own alot of cards hehe! Anyway, that card will run COD2 but with the setting down a bit. This was on an AMD@2.4 system. In fact, i remember using dx7 so i could having everything set to high. It looked nice too!
Now CSS and valve games run great using that card.
o yeah, that card--OC'd like a mutha!
are they even manufacturing them anymore? and i also thought they were only available in europe...
o yea and i run it with dx7 everything on high 1024x768...looks awesome lol
They also made regular 7800gs cards that had the g71 core that was crippled in the same way as the g70.
You just have to find out what brands used it in what versions. Maybe the latest BFG version has it... I know evga made a g71 version too.
