question about 7600gt versions
cukes38
can anyone tell me if there is a meaningful difference (aside from $10) between these two cards:
http://www.newegg.com/product/product.asp?item=N82E16814130073
vs
http://www.newegg.com/Product/Product.asp?Item=N82E16814130062
the only difference that i can see is that more expensive card has the old vga connector, and the cheaper one has two dvi ports.
but why have 76 people bought and rated the $130 7600gt while no one has rated the $120 7600gt? is there any reason to spend the extra $10?
thanks in advance.
Probably just a mistake of some sort the cheaper one is the better of the 2 but thats only because it supports Dual-link DVI
