Question about 4890
Here are the parts to my computer
GIGABYTE GA-G31M-S2L LGA 775 Intel G31 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128078
Intel Core 2 Duo E4600 Allendale 2.4GHz LGA 775 65W Dual-Core Processor(oc'ed to 3.0)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115032
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
XFX GeForce 8800 GT XXX Video Card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?Sku=P450-8836
Whats the rest of your system, and any overclocks?
Also, that raid max would be like playing Russian Roulette with your rig...
my psu now is a 500watt but i dont know the what brand or anything becuz i took it out of my brothers old pc
oh forgot to as what res do u play at? im beginning to think the 4890 would just be overkill
