Hi All: I purchased a bunch of these Rosewill Hyperborea 140mm & 120mm fans. It uses a 4-pin connector.
Link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200068
Will this 3-pin fan power splitter work with 4-pin? If so, will the fans just run @ full speed?
Also do you think Hydro Dynamic bearing is better then a double ball bearing? I have always used Vantec Stealth fans here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999614
Any insight would be appreciated!
Link:
