I currently have an old CM Stacker that's huge. I'm ready to go with something smaller but am having trouble finding a case that will work with my current system (see signature). I've found a few "maybe's" but nothing that I know for sure will fit.
I did some research and based on measurements various users gave I took a chance with the Lian Li PC-V800B. It turns out this case was too small by 1 inch (doh! so close) to fit my video card with the Corsair PSU. So, I now have all the parts back in my old case and an RMA open with Newegg to return the case. I was disappointed because that case was really nice.
Now I ask for some recommendations. I am looking for a case that meets the following requirements:
- Must support uATX mobo's (it can be a full ATX case as long as it also supports uATX mobo's)
- Must support standard ATX PSU
- Must provide sufficient space for an XFX Radeon HD4890 video card. (as long as the entire mobo has clearance (i.e. nothing hanging over the motherboard) then there will be enough room).
- Would prefer to keep the Auzentech but am willing to sacrifice it and use on-board sound if needed.
- Must have room for 1 internal DVD burner
- Must have room for 2 3.5" Hard Drives.
- Must have decent airflow (it's a gaming PC after all) (also not afraid to do some minor mod's if required)
- Would very much prefer a "desktop" case (horizontal) that will support a 24" LCD monitor sitting on top of it. A cube case may also be an option. I'm trying to avoid towers but will go with one as a last resort.
- Must be black in color
Does anyone know of anything that meets the above requirements and still looks half decent? I was lookign at some of the new Lina Li's
http://www.lian-li.com/v2/en/product/product04.php?cl_index=1&sc_index=25&ss_index=64
Unfortunately, the pictures are angles that don't allow me to see if the entire motherboard will have clearance. The problem I had with the PC-V800B was that the PSU "hung" over the motherboard by about 1.5" and invaded the space where the video card needed to be.
