WarMace
- Aug 25, 2004
http://www.supermediastore.com/cd-d..._id=060926emailTaiyoYuden_4240_ACC15X0155-001
Expires 10/2/2006
Supermediastore.com is selling their allready low priced disk "Bibles" on sale right now. I bit a while back to organise and archive my companys old disks and mine is easily 3/4 full of disks and shows no flaws in quality. No loose strings, the nylon is thick, the sidewalls are double nylon, so you dont have to worry about the zipper. I wouldent be nervous if it flopped around because its not cheap like the one i picked up at wallmart before it.
One word of caution, dont try to set up a PO with this company, theres a reasion i call them "StupidMediaStore", just use a company credit card if your corporate.
closed image
(yes it comes with all the sleves)
opened image
Other deals:
http://www.supermediastore.com/supermediacoupon.html?WT.mc_id=060926emailTaiyoYuden
EDIT: Don't be ganking bandwidth by hotlinking images. - Lethal
Sorry, wont happen again - WarMace
Expires 10/2/2006
closed image
opened image
Other deals:
