m3ta1head
777
- Feb 22, 2006
Is it possible to run a Quadro FX580 in dual card config with any of the new gaming cards in Win7? The Quadro is CUDA enabled...
Are you sure the 580 will perform better then a gaming card with a ton more shaders though, what program are you using?
I'm building a CAD workstation, and I want to make it game-capable. Any possible way to do this? I already have the Quadro card-would a 5850 or GTX275 significantly outperform the Quadro at AutoCAD, 3dsmax, and Solidworks?
