Quad SLi
lee63
Im looking for a PSU that is normal size that will run Quad Sli, I have a blow hole at the top of my case with a 120mm fan and the bigger PSUs wont fit, I think that somthing that is 700w plus would work fine.
Thanx in advance
Define "normal size."
Are you saying it needs to be 5.5" or can a 6" or 6.5" deep unit work?
Bummer :mad:
EDIT: I think it will fit :D Now the question is will it run Quad SLi with the hardware in my sig ????
revenant said:
Or try the ePower xscale 750...
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=177&products_id=3818
or the Athena 850 (which I think is the same psu as the above, topower makes them both)
http://www.newegg.com/Product/Product.asp?Item=N82E16817104126
Same split/combined 12v rail switch.. looks /very/ much like the same one to me.. anyways.. just a couple more ideas. :D
Thanx man, but buy the looks of things I might be ok with what I have http://www.techpowerup.com/reviews/NVIDIA/QuadSLI/14 my PSU has 650w peak http://www.pcpowercooling.com/products/viewproduct.php?show=T51ASL thoughts please.
You have a 20" monitor and you want to run quad SLI... LMAO.
Whats it to ya anyway???? who says Im gonna have a 20" LCD with Ouad, ever thought of that GENIUS :p :p :p No input at all, I would expect a little more from somone that is 2[H]4U :confused:
Not funny at all.
Makes perfect sense for games like fear or AA levels 4xAA and above.
Go read some reviews, thanks. Oh, and fix your sig, you can't do tags in your sig.
