I don't know what Peltier is...I thought Phase could get it down to at least negatives.
http://en.wikipedia.org/wiki/Thermoelectric_cooling
I don't know, 5C or 41F seems low for watercooling... Maybe just me..
well if you do go and get a vapochill you would have to modify it to handle a quad, it's acually better to have somone build a custom phasechange system, unless you pick up a used one crazy cheap. now it's time to try to push it some more
the only thing your crazy computer is lacking is a decent vid card, otherwise i am very jealous. why are you only running a 7800GT and not something better?
4.4 Ghz seems disapointing for Phase change.. Expecting least 5 Ghz ish on Phase..
just curiouse where have you seen the other better overclocking samples? prime stable offcourse.
Well I don't really have time to make sure all of them are prime 95 stable, but here are a few.
4.67 Ghz: http://www.anandtech.com/cpuchipsets/intel/showdoc.aspx?i=3184
4.25 Ghz: http://www.neoseeker.com/Articles/Hardware/Reviews/qx9650_penryn_review/18.html
5 Ghz +: http://www.nordichardware.com/Articles/?skrivelse=519&page=6
4.32 Ghz: http://enthusiast.hardocp.com/article.html?art=MTQxMSwxLCxoZW50aHVzaWFzdA==
Sure there are more, but a quick google search pulled those up, only looked at first page..
I have 2 QX6800's and could get 3.6Ghz stable since I have stock cooling on both. Both of em could go 4.0Ghz but it'd get way too hot when running orthos.
Q6600 @ 3300Mhz Thermaltake TiG2 Heatsink and fan at 1.3 Volts
I can boot into windows all the way upto 3500Mhz but it is not Prime stable, Core 3 fails all the time no matter how many volts or how cold im running.
