Xeon X3210, which is basically a Q6420
I cannot understand Intel's new naming schemes.
What is an X3210 and what is a Q6420?![]()
Thanks.
1st thing, keep your jaw attached...
2nd thing, the X3210 is a Xeon quad-core running at 2133 MHz. The Q6420 is the same thing but this doesn't exist. Q6600 is a quad-core running at 2400 MHz and will be sold for 266$ in 2 weeks. The Xeon is the cheapest quadcore you can get on the lga775 plateform
Xeon = server quality and Core 2 = desktop quality
I wouldn't call the X3000 series any better quality then the Core 2s, they use the exact same cores, it's just meant for entry level single processor servers, same thing they used to use the P4s for. Just a response to AMDs 1XX and newer 12XX Opterons for the single processor server market. You'll notice the fastest X3200 series Xeon only runs at 2.4, they're scaling back the clockspeed for stability, not making a "better" core 2 quad in the LGA775 package.
You're better off with the 9x multi of the Q6600, so it runs at 3.0 with a 1333 fsb.
I'm totally aware of this but if you want to run 8x400 for a nice 3.2, a X3210 would be a better choice with a 8x multiplier.
True, but how many quads are hitting 3.2 on stock cooling or 400 mhz fsb's for that matter. Especially ones that fold 24/7. Plus, you can always run the Q6600 with an 8x multi if you are so inclined, but you'll never be able to run the X3210 with a 9x multi. Also, I imagine you'll be able to find Q6600s much easier (therefor meaning cheaper) then the Xeons...atleast that's how it's been in the past.
