??? Quad Core Problem?
DudeItsMe
OK, I know this is going to sound really odd, and it COULD be my imagination, but I think I'm having a problem with my quad core.
I was playing WoW today while watching Pulp Fiction on the other screen in Windows Media Player. All of the sudden, things seemed to slow down and my frames dropped to around 30ish. This also happened to me last night while playing WoW, and I had no idea why.
I started up my sidebar to check the CPU usage, and it was at 100%, which is odd. Playing Company of Heroes, I never managed more than 55%. So why would WoW take it to 100%
I also noticed the gadget is only showing one bar for CPU usage. This got me to thinking, is it using all four cores? After doing a bit more digging, I checked my Task Manager, and it's only showing one CPU Usage graph. Again, doing some digging on the net, I realized it should show one for every core... so if it's showing only one graph, does that mean it's only using one core?
So if my suspicions are right.... what could possibly make my computer drop from using four cores to one? My CPU is only running at 40 C, I know it's never broken 50 C, so heat couldn't be a problem...
Doing general surfing while watching Pulp Fiction, my CPU Usage is going from 30% to 65%.... this definetly seems high.
In task manager, click on view, and make sure, under CPU history, that its set to one graph per CPU, instead of one graph for all CPUs. In task manager, which process is using all 100% of the CPU?
Yes, it is in fact set to one graph per CPU. Thanks for pointing that out though, I hadn't thought to check that option (didn't know it was there).
I'm almost positive now that the processor is only running one core (although I didn't know it was possible). I just play CoH and the CPU usage was 100% the entire time (it's now down around 10-20% and I just exited). CoH ran fine, but the frames were lower than usual. Before I couldn't get CPU usage above 55% in CoH... now it was at 100.... so there's definetly a performance problem going on.
I can't possibly think of what would make this do this.... my best guess is a BIOS setting somewhere or something, but I wasn't messing with that.... just playing WoW.
Also: I did a system restore to before this problem occured.... and it's still doing the one core thing.
I wonder if replacing the proc would have an effect? I have to RMA my memory, because I have a bad stick.... which really sucks, since my system will be down. I have some really bad memory I could put in there, but I'm not sure it's worth it.
I kinda doubt it's a problem with the processor though.... and I still can't find anything. All google turns up is 10000 news articles.
hey i had this same problem going from single to dualie in vista.
IIRC, the way i fixed it was by going into device manager, expanding "+computer", and right-clicking "ACPI...". Left-click "update driver" on the popup menu, and select the search automatically option.
best of luck!
Thanks for the tip, but so far no luck. It gives me something to dig at though.
It said the driver was up to date, and I can't roll back.
The device manager DOES show four cores though.
Looks like I'll have to mess with this after work tonight.
Problem solved!!!
Before I get into what the problem was, I want to say thanks to everyone that tried to help me... I really do appreciate it because this was such a frustrating problem for me, especially after having one bad memory stick already.... who needs more problems?
Next I want to come out and honestly admit I'm stupid (dee dee dee). Yes, I know, it's harsh, but hey, I deserve it this time :eek:.
Anyways, here's what happened.
I installed a program by the name of Vista Boot PRO in order to get my Belkin Nostromo N52 working. It's not Vista Compatible, but I LOVE my Nostromo... I would dual boot just to use it if necessary. And I DID get it working too! Now, in this program there is an option to limit the number of CPU's allowed. Obviously, it was checked. HOW it got checked, I don't know? Maybe I did it on accident (ADD FTW), either way, that was the problem.
I could have just said I fixed it and left it at that, but JUST IN CASE anyone does something this dumb again, they'll know how to fix it. Of course it was something simple...
