quad and sli (need a lil help please)
shinygecko
Looking to build a new water cooling system and i am kinda lost with the choices.Right now i am running a thermal right ultra 120 extreme with 2 120mm deltas on a q6600 G0 at 1.525 volts at 4ghz. Also have 2 8800 gt's with the stock coolers i would also like to ad into the loop.
What would i need to keep my CPU running at this and also overclock the vid cards moderately without anything crazy like vmods.
I need all of it to fit inside the antec 1200 which should not be too much of a problem with mounting the rad in the front (http://www.youtube.com/watch?v=mNagN1PQw-4&feature=PlayList&p=4CEB09255BCC70CC&index=0).
Could i get away with the dual 120mm rad? or would i need the tri because i am not too sure if i can fit a tri in the front...
You will need a Tri rad ideally. TFC/TC or the new XSPC RX series rads are your best choice. IMO I'd go with the XSPC RX rads as they perform about the same as the thermochill for a bit less.
Also...isn't 1.525 volts on your Q6600 a bit...much?
XSPC-RX360 or Swiftech MCR320 (rad)
http://www.jab-tech.com/XSPC-RX360-Triple-120mm-high-performance-radiator-pr-4384.html
http://www.jab-tech.com/Swiftech-MCR320-QP-K-Triple-120mm-Radiator-pr-3320.html
MCW60-R (vid block)
http://www.jab-tech.com/Swiftech-MCW60-R-VGA-cooler-Rev-2-pr-4271.html
Swiftech Apogee GTZ (cpu block)
http://www.jab-tech.com/Swiftech-Apogee-GTZ-Extreme-Performance-CPU-Waterblock-pr-4246.html
Swiftech MCRES-Micro Rev 2 (res)
http://www.jab-tech.com/Swiftech-MCRES-Micro-Rev-2-pr-4312.html
Swiftech MCP655-B (pump)
http://www.jab-tech.com/Swiftech-MCP655-B-12-VDC-Pump-Without-speed-controller-pr-3803.html
How does this stuff look?
Would u change anything?
I am also unsure of what tubing size to run, i researched it a bit and it seems like a big war between the 7/16 and 1/2.
lol yea the vcore is abit much but its teh only way i could get it stable, speaking of which should i invest in a northbridge block?
If i wanted to add another 240mm rad to the top of the case how would i had this to the loop so i could avoid running 2 seperate loops and have to get another pump. like cpu>>vid>vid>rad>rad ect...
I'm not sure a tripple would be enough ?
im running a gtx260 (oc'd) and a e8600@4ghz and am getting temps of arround 45° on the cores and 48° on the gpu when playing demanding games for a while (single and double swiftech rads) which has allready got me thinking of getting another double rad.
surely an OC'D quad and sli 8800's will need at least a quad? well either that or I ballsed up lol
Ok did some measuring and came up with a new plan and thats 2 360mm rads back to back using 9 fans (3fans then rad then 3 fans then rad then another 3).
Does that stuff look like it would work out together?i keep reading things about low resistance and high resistance stuff and how certain things work better together or somethin?.
would this even benefit this way because of the hot air from the first rad?
i attached some pic to kinda show ya what i mean
Ok i think i made my decision on everything just wanted to make sure i am not forgetting anything and i can pull the trigger on this.
From what i read a rad sandwich will do about 40%-50% better than a single dual pass rad.
~~~Watercooling setup~~~
Swiftech MCR320-QP-K Triple 120mm Radiator
$49.95 x 2 = $99.90
YATE LOON 120mm Case Fan - D12SL-12 BLACK
$3.20 x 3 = $9.60
Swiftech MCW60-R VGA cooler - Rev 2
Swiftech MCWRamcool/A VGA memory waterblock
$54.95 x 2 = $109.90
Swiftech MCP655-B™ 12 VDC Pump Without speed controller
$64.95 x = $64.95
Thermalright HR 09 - Type 4 Mosfet cooler
$19.95 x = $19.95
Swiftech Apogee GTZ Extreme Performance CPU Waterblock
$61.95 x = $61.95
Tygon R-3603 7/16" ID 5/8" OD Chemical Tubing - AAC00033
$2.00 x 5 = $10.00
Swiftech MCW30 Chipset cooler
$24.95 x = $24.95
UV Dye - Blue
$4.95 x = $4.95
$24.95 x = $24.95
Sunbeam 12" DUAL UV Cold cathode
$5.99 x = $5.99
Subtotal:
$437.09
Shipping cost:
$14.08
Total:
$451.17
