I downloaded the trial version of QSoft Ramdisk enterprise 64-bit for Win7 and would like to allocate 8GB of my total 16GB RAM. I read the tutorial about configuration options but I must admit it's over my head. Any help would be appreciated!
Options I understand: drive letter (R, Disk Size (8GB), File System (NTFS)
I don't know how to configure:
- Use of "Resident" Memory...
- "Allowed" (default 1024MB)...change to?
- "Reserved" (default 32MB)...change to?
- Use System Memory (currently checked)...under "Allowed" slider shows default of 3360MB
- Volume ID - default is abcd5678 (can I change this to anything?)
- Volume Name: RAMDisk (guess I should stick with this?
Also, saving the image file:
- save in "compatible" or "extended" format?
How often to save to image file?
- synchronous write
- or periodic say 1 min interval?
Any help greatly appreciated!
- synchronous write
