Q's about Hard Drives & Boot Floppy
cu2cool
Two questions I was wondering about:
1.) What are the benefits to partitioning a hard drive? I've always believed that it was to leave more memory available on the hard drive for temp files, ultimately to maximize performance. I also personally partition in the event that I need to reformat, I only have to reformat my C drive and not the whole hard disk.
2.) What is the purpose of having a bootable floppy? I created one and tested it out. All it did was boot in a DOS prompt. I couldn't find a way/command to access windows on my C drive, which is what I thought it was for.
You might want to try the Disk Storage section, they may be far more willing to accurately assist you there. IBTL.
It's a good way to keep your OS and programs separate from your data. For someone like me who has OS troubles way too often, it's nice to be able to just reformat that one partition.
I did post their too, but no one responded...
With regards to the boot floppy--make sure your boot floppy's system knows how to read the format of the hard drive. For example, a Win98 boot floppy won't read NTFS. Boot disks are usually so you can do repairs on a non-functional system, but as you found out, it's not always very easy.
RE: partitioning--In an ideal world, you'd have at least two hard drives--one for the OS and programs, the other for data. That way, if one fails, the other will be fine. Partitioning is kind of a poor man's version of having multiple hard drives.
Well this doesn't fall under the guise of Distributed Computing, but maybe you can get some help in General Hardware.
