Heres whats going inside:
MOBO: GIGABYTE GA-K8N51GMF-9 Socket 939 NVIDIA GeForce 6100 Micro ATX AMD Motherboard - Retail
HDD: HITACHI Deskstar 7K80 HDS728080PLA380 -0A30356 80GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
RAM: Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model PSD1G400KH - Retail
DRIVE: NEC Black IDE/ATAPI DVD Burner Model ND-3550A - OEM
CHIP: AMD Athlon 64 3200+ Venice 1GHz FSB Socket 939 Processor Model ADA3200BPBOX - Retail
PSU: Thermaltake TR2 W0070 430W Power Supply - Retail
**Video is onboard**
Computer is going to be used for basic word processing and internet usage.
I was thinking about this one: Foxconn mATX case
I measured out how big the area where the case needs to go and the Qpack is too wide to fit. So whats the next best solution. Im on a budget so please dont suggest super expensive cases. Something in the 30-60 Range would suffice. PSU or not, doesnt matter because im getting the thermaltake 430watt, unless the PSU coming in the case is equal or will suffice for the application.
Thanks for suggestions and help!
