Qpack Temperature Probes
LittleGuy
Hey Qpack owners, I am curious how you used the 2 temperature probes in the case. One is supposed to be for the CPU and the other for a Hard Drive. I am thinking that it would probably be more meaningful to use the second probe not for the Hard Drive, but put it on the video cooler. I am not Oc-ing, but I just don't get the value in monitoring the drive's temp over the video card. Any guidance or thoughts?
Thanks,
LittleGuy
I use one for the CPU (stuffed under the motherboard), and one for the GPU (stuffed wherever it will fit under the heatsink). You could use them for anything in the case though, the leads are long enough to reach pretty much anywhere. I also used it it initially for the case temp, and moved it around to see if there were any hot spots.
