Qpack Show Down!
antok86
i wanted to see what peoples qpacks here look like...modded and not modded alike. so post em UP!!....
here are some of my qpack...ill post more pics and inside shots
holy crap! someone stole your windows and replaced them with some metal junk! they also took your monitor and left a deck of cards instead!
post some pics of the other black qpack thats behind this one in the bottom pic.
uh...rofl...? LOL
Looks like hes transfering files from one qpack to the other, so after hes done id like to see pics of that one too! LMAO..j/k :D
its pretty cool how he has them wired up exactly the same, and even on matching desks! i'd bet those guys took the monitor from that one and replaced it with a deck of cards too.
nice box. i have the windowed one, but i like the way those look better. but the windows made it a bit easier to add suckhole/blowhole on the sides.
buy a 3 1/2" hole saw. this will be good for a 92mm fan. if you dont mind cutting the horizontal supporting beams you can put in 120mm fans. i didnt want to do this, so i put in a 92mm smartfan2 with blue led's. try putting just one on the left side first. this may be enough. about 2 inches back from the front and maybe an inch from the bottom. now that i think about it, since you dont have a window, you might be able to squeeze a 120mm fan under the beams. measure it and see. the window starts a little way up the side of the panel, so i could only fit the 92mm. mask off both sides of the panel before cutting, and use some kind of clamps to hold it flat on your bench. if you can fit the 120mm, you might want to check out ace hardware, they will rent you a 4 1/2 inch holesaw by the hour. one of these with an arbor and starting bit will run like 60 bucks, a bit much to pay to only use it once or twice. the 3 1/2 is much cheaper, for some reason, like $25.
good luck.
ps you can print out a template for the screw holes. ill put the link here when i dig it up.
Here is some pics of my watercooled Qpack.. I am definately interested in seeing some good pics of other Qpacks out there!!
btw: no making fun of my "winnie the pooh" tablecloth. ;)
that's about it for me... Keep 'em comin guys!
what rad is that?
I put a grill on, but haven't taken a new picture and getting a new psu, will post pictures when done :) I also redid the wires super pimp
Black Ice Extreme "limited edition" in chrome.. limited edition meaning that the ports on it are permanent instead of screwed in, nothing else... lol..
has anyone puta 80mm blowhole/sidefan on these? havent really seen any....
Looking good guys. Apparently the black Qpack is the favorite.
btw EZ, post your link like this:
ohh, it's nice and small (compared to me heatercore :eek: )
PCduster what power supply is that? Also I know you can replace the plex side panels with stronger acrylic but will 1/4" acrylic fit easly?
Thanks
The PSU is a sexy OCZ Modstream :D
Wanted to get one of those but I got one of the free-after-rebates Ultra XConnect 500W PSUs instead.
Thanks
No 1/4 is way too thick
I got like 3/16 or something like that, maybe it was 5/32, I can check when I get home
And i had to cut a bit off the black inserts cause it was hitting the psu, 1/4 would be too thick
There is no point either going thick, thin windows are easier to drill, cut, and are lighters, and are more clear to see through
I have added other things like better fans, etc..But have not had time to take updated pics...
Heres mine, No real mods yet, but I have a few planned, getting an OCZ Modstream soon as the Fortron 350 isn't powerful enough. Also I would like to get a differant Motherboard, maybe the SLI board that everyone is talking about the last couple days. I also want to get the Zalman VF-700 LED heatsink so it matches the CPU heatsink.
Sorry for the really bad pics.
I'm planning on another Q and will decide later on what PSU and DVD burner.
I miss my 7800gt and will wait for the 7900gt.
I like the NEC but they limit me on PSU.
The XCLIo really isnt bad but a tad noisy for me and I really like the enermax's. I also believe they might be a tad quieter.
I believe the XCLIO is 150mm long. The NEC is 190mm
X-Pack
Biostar T-Force 6100 939
Opteron 146 @ 2.7
G.Skill HZ 1GBx2 @ 3 4 3 1:1 @ 2t. Couldn't do 1t on this board
Zalman 7700 CU
X-Clio 500w Goodpower
EVGA 6800GS
Arctic Cooling VGA cooler
74 GB Raptor
300GB Seagte SATA
NEC DVD Burner
BENQ Lightscribe DVD Burner
Scythe S-Flex 120mm
2 x 12" Cathode
Logitech Mx 518
Flexiglow mouspad
