So i picked up a QPack from Newegg a while back. Had to send the first one back because the PSU would shut off at the slightest hint of movement (like if touched it, heh). Seems that was a common problem, so i just RMA'd it. The replacement has been working ok so far, but in some games, the PSU has started making a slight hissing/buzzing sound. As far as i can tell, the more graphically intensive the game, the more likely it is to make noise. Though it also happens on the menu screen for Painkiller though, which is a static image, so i'm kinda confused.
My question then: is it normal for a PSU to make noise? It's not the fan, and it doesn't sound like dangerous electrical arcing or anything, it's just a slight annoying buzz. It is related to what's on screen, for example, i might be in an open level, if i look at the sky, no noise, but walk up to a building, noise. If i get attacked by a bunch of things, no noise, etc.
My old case (an FIC Ice Cube) had a far smaller PSU (rated at 220W), and never gave me any problems of this kind.
Things in my case: an ATI 9800Pro, WD120gig drive, and an Optowrite DVD burner.
