Qpack or shuttle SN25P?
Godlovesaterrier
I cant decide if I should go with a Qpack or shuttle system. I know Im going to get the following.
X2 4400 (have no plans on overclocking really)
atleast 2gigs, would like to have the option to upgrade to 4 but it is not necessary
7800GTX 512
onboard sound is fine
I would like to have it pretty silent as my Sk41g is a screaming monster of sound. Im not sure what else I need
I have a QPack setup and it is nearly silent. I would vote QPack.
Swap out the PSU for an Enermax 420W Noisetaker, swap out the rear fan with a Vantec Stealth, and use a Swiftech MCV64-X to cool the processor. You won't know it is on.
I had an SN25P and swapped to the aspire and love it :) lots more room and better upgrade options.
It also is far quieter (now I have an silencer on gfx and quieter 120mm fan) than my shuttle and cheaper ;)
The SN25P might be made a bit better but not as good as the X-QPack ;)
I have both. I like both....
Its a toss up
I currently would get the QPack with either teh new MSI Tforce 6150, Biostar, or Asus. Mostly because of the cost of the shuttle and nothing more. I think the Tforce 6150 is just as fast as the Nforce 4 Ultra on the SN25P. I did not see any difference in overclocking or otehrwise. A good 6150 board with gigabit, firewire, and the 850 audio is similar if not a true push against the SN25P. Also with your aftermarket cooling options, you may be able to make a quieter, or faster version of your machine with the X-QPack for comparable money as the SN25P. I mean X-Qpack, high end Power supply, Heatsink and Tofrce Board are less than the shuttle (albeit, maybe not by much).
Overall I think they are both a good option.
I'm debating the same thing as I plan on upgrading over this Xmas. My first priority is silence, and my second is size, because I need to carry this box on a plane at least 4 times a year, up to 8. I heard it is wider, anyone know if it'll fit in a standard carry on bag / backpack? My guess is I'll probably go QPack this time around, because I want the silence, but I'm just worried it might be a little too large for easy carry-on.
Anyways, I like this thread, more suggestions please!
Having owned both, I'd say if you are going to travel with it 4 times a year DEFINITELY get the SHUTTLE.
The only problem I've had with my SN25P since March is the orginial nvidia drivers and Bios were somewhat unstable. But not a problem since upgrading these.
There is a good setup guide here in the forumn to keep you out of trouble. Do a search.
However, I've pushed mine though the ringer with video, games and lots of other multimedia. Setup properly it is as quiet or quieter then any desktop I've ever built.
Performance is awesome.
My 2 cents
