Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I third the nomination. I've owned a QPack in the past, and currently own a Microfly. The only area the QPack beats the Microfly is in the top/side cover. The Qpack uses one piece of aluminum to cover the sides and top. This adds some structural rigidity. The Microfly uses three separate pieces of aluminum that don't fit tightly. I notched the rails where they attach, and used some single sides foam tape to fix this problem and my Microfly is just a strong as a QPack now. I also used some cardboard and heavy tape on the insides of the sides/back covers to insulate them a bit. I will probably end up replacing that with some type of foam or plastic. The Antec Aria is an excellent example of a case with high quality side panels. I'd kinda like to duplicate that.
You can also fit a full size power supply in the Microfly without having to use a short optical drive.
IMO, Ultra/Chenming/Aspire/whoever needs to learn one thing from the Aria--Build quality. The Aria may have a weak PSU, and horrible temps, but it's a rock solid case in terms of structural rigidity.
High temperature will kill your CPU, motherboard, hard drive and video card. What is point to have a solid case when it destroy all the component inside.
