phillyp1982
- Dec 25, 2005
on the qpack, is it possible to make an 80mm fan hole on the window on the left side? I know that the window is plastic and not plexi, but i would love to put a fan on there to blow on the video card.
TimKLL said:The way the cheapy plastic window on the Qpack is mounted makes it pretty easy to replace it with a little more durable panel. You can get the Lexan from Home Depot for $10-$12 or so and cut it to match the size. The stock window is mounted with the little push-pins (which I am looking for more of...) and if you push the center of the pin out the whole window comes out very easily. I've seen a lot of debates/comments here on how to cut the stuff - I had really good luck with a sliding compund miter saw, and then used a coping saw for the corners. I drilled matching holes with a drillpress, but a hand drill would do the job.
A little more durable panel makes mounting a fan a little sturdier, but even so, consider this fan: http://www.newegg.com/Product/Product.asp?Item=N82E16835118212
It is a slim profile (15mm) fan and really seems like a nice one. It comes with a little pigtail from Zalman to down-volt it without having to swap molex plugs out. Either way it really is a quiet fan and the "slimness" of it would keep from overpowering the window.
I am now thinking about putting this fan in this way thanks to your post.
Steeeeve said:I got a 92mm in mine. It wasn't that hard..I actually mounted the fan to the bar that goes across the qpack and that holds up the fan...works nicely and you can lift the cover without having to disconnect the fan.
