GeminiCool
- Jan 11, 2005
I am so very tired of reading these transfer rates on these router reviews! I mean, come on is anyone who actually has a 50Mbps+ net connection actually going to buy a home grade router?
So DLink, Linksys, TRENDnet all offer some QoS filtering but there is only one (1) review on the entire net that I've found that actually attempts to measure this feature. Big props to firingsquad for this: http://www.firingsquad.com/hardware/d-link_dgl-4300/page5.asp
If your in a small business or home setting and have several PCs and want to assign a priority of access based on application, such as gaming, or VOIP, or web shopping, what level of QoS do you need? How well does this QoS work?
Let's say you have a 5M/368k cable connection. You play Supreme Commander on two PCs and someone else in the house begins browsing the web or using facebook. It's likely you begin to see lag spikes upward of 1-2 seconds. QoS should fix this, but what level of QoS is needed? If you buy a TRENDnet with the stream engine how far apart do you need to set the priorities? 1 to 255 or 10 to 50?
Are there any router reviews of QoS that measure how well they work? If I have a 60ping typically, as I add a Medium QoS were does the ping go? If I add a Low were does the ping go?
Does anyone know these kind of answers?
